I want to start with the ArduIMU+ V2 (Flat) as AutoPilot for my kerosine powered Jet.
It's fast about 180,2 mph ;-)
Would be nice if someone could supporting me to choose all the needed parts for a full functioning AutoPilot.
Thanks for help!
Greetings,
Flo
Part list:
1. ArduIMU+ V2 (Flat)
2. uBlox Adapter
3. 50 Channel GS407 Helical GPS Receiver
4. EM-406/uBlox Adaptor Cable
5. Official Ardupilot FTDI Cable
6. HMC5843 - Triple Axis Magnetometer
7. 2x10 Break Away Right Angle Pin Headers
8. ArduStation Kit
9. 2x 2mm 10pin XBee Socket Sparkfun PRT-08272 Sparkfun
10. 2x XBee Pro 900 Wire Antenna Sparkfun WRL-09097
The first thing missing on your list is an ArduPilot board. Also you will most likely want an ArduPilot Shield kit. The ArduIMU board is not set up to be a stand-alone autopilot. ArduPilot is. The Shield kit adds an airspeed sensor and support for thermopiles. There is currently no "released" firmware support to use ArduPilot and ArduIMU together, but that is coming.
I would recommend you find another airframe platform to work out the autopilot system first before putting it in your turbine.
Hi Doug,
thank you for your answer. What would be the best choice for an AutoPilot? Wait for the ArduPilot Mega?
I have a some more airframe platforms for try out.
Florian
It's only fair to point out that the Ardupilot is developed on far slower airframes than what you describe, and that whether intended or not, all of the algorithms and particularly the PID gains will be clustered around slower machines. There may be no known limit to the airspeed, but if it is safe to say, no one here has yet described testing this platform at > 100 mph, so you would be in clearly uncharted waters.
I'm not sure where you intend to fly that thing, but it brings up at interesting fact - that by the US failing to create a reasonably safe envelope for private UAV's it has by default created a wild frontier where kerosene tanks are whizzing around at 183 mph on cruise control. What could go wrong?
that's my thing to explore uncharted waters ;-)
I fly that Jet with my FX40 2,4Ghz with no problems for over 3 years!
I like to use the AutoPilot more for flight stabilisation, not as a UAV.
Here is my new airframe:
Greetings,
Florian
Why don't you try the FY21AP? Its a 3 axis accelerometer + gyro, with stand alone autopilot with RTH and auto circling. Someone has tested it to 100 km. But not on a kerosene turbine though (not yet anyways).
http://shop.fyetech.com/product_info.php?cPath=21&products_id=22
BB
Hi borneo bear,
Thank you for your recommendation. I use the GluonPilot, it's an all-in-one IMU-based module, works perfect for me. Top speed was over 140 mph !
(I have sold the little kerosene turbine, now I use the Hoffman Magnetics Storm Wild Beast EDF)
Florian
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
