Tags:
Permalink Reply by Toby Stein on November 10, 2009 at 9:34pm
Permalink Reply by Scott Plunkett on November 11, 2009 at 3:24pm
Permalink Reply by Morli_ on November 11, 2009 at 9:20pm
no, I use something (screwdriver etc) to push the buttons. It's not a big issue. But if I find a solution I will post it.
Any idea on this ?
Best regards,
Ric
I had the idea to use some fuel silicon tube, but never did it.
Thank you for sharing your ideas. Please post results and pictures if you find a solution.
Best regards,
Ric
Permalink Reply by Andrew Fernie on March 2, 2011 at 7:54pm It can work with the standard buttons assuming your case material is not too thick.
1. You need to use only the pin headers (not the sockets) so that the processor board is permanently soldered to the LCD board. Put the cards as close together as you can get them without touching and put some form of insulating material between the cards so that they won't short. I had to trim the voltage regulator pins.
2. Cut the hole in the box and push the LCD in as far as it will go. I used some hot glue to hold it in place.
By doing this I have the buttons above the case by about 1mm - works well. This was with a standard Hammond box.
When I first built the Ardustation I had used both the pins and sockets to join the boards. It is possilble to remove the sockets - gently pry off the plastic casing then extract one of the metal sockets at a time. Clean out the holes and solder the two cards together using only the pins.
I had a tough time getting the hole for the LCD exactly the right size - it ended up a bit uneven around the edge. Once I did manage to fit and glue it I ran some masking tape on the case about 3mm-4mm away from the LCD. I then ran a bead of black silicon sealant around the edge filling in the gap and smoothed it out with my finger. I removed the tape before the silicon set and that gave a nice finish.
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.61 members
57 members
95 members
108 members
617 members
© 2012 Created by Chris Anderson.
