what means the Ardustation values and particularly:
Waypoint screen,
- RSP (it show mainly about 35, what is this?)
Navigation (Roll/Pitch) screen,
- DAL
Tracking (Is this antenna tracking?),
- Dist2D and Dist3D
- Angle
- Alt (is this the same as the other screen?)
- Dir
Thanks!
Ric
Tags: Ardustation, Values, Wireless
Definitions are here, but the basics are:
Definitions low rate:
LAT: Latitude
LON: Longitude
SPD: Speed over ground from GPS
CRT: Climb Rate in M/S
ALT: Altitude in meters
ALH: The altitude is trying to hold
CRS: Course over ground in degrees.
BER: Bearing is the heading you want to go
WPN: Waypoint number, where WP0 is home.
DST: Distance from Waypoint
BTV: Battery Voltage.
RSP: Roll setpoint used to debug, (not displayed here).
Definitions high rate:
ASP: Airspeed, right now is the raw data.
TTH: Throttle in 100% the autopilot is applying.
RLL: Roll in degrees + is right - is left
PCH: Pitch in degrees
Thanks very much Chris for your answer.
I already know this values. On the other side I'm not able to find the values I'm searching for. They're not mentioned. These are the ones I wrote in the first post.
I only found the RSP (roll set point), but what is this for?
Thanks for any help.
Ric
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
