Hey guy's
Our team is interested in ArduPilot IMU. I am wondering if the IMU will work in conjunction with the thermopile sensors? Is this the arrangement?
Monroe
Team Prometheus
http://teamprometheus.org
Check out the Quad Pod in the pictures section.
Imu's drift and that's one thing the Ir's can help with.
Monroe
i assume u mean laser range finder, but that wouldn't help correct imu drift
We need to implement a laser range finder as well. We may use ultrasonics at first (on earth) :)
Hi all,
I don't want to create unnecessary another topic. I just want to know a bit about IMU 6DOF razor (Red) from sparkfun, where it stated required 3.3V regulator. Not mentioned about Vrefs for gyro chips. Which I believe will require 1.23V right?? Funny thing is it is connected to OUT pins where LPF part and also connection for external Vref. I didn't give any to those pins as i was not aware. But It seems to be giving out correct zero rate value. So i don't really know if i need 1.23V ref or not. Can u suggest n e ??
Regards
PG
Spell it with me: T H E R M O P I L E. One "h."
A thermophile is something which likes heat. For example, teenagers residing north of the Mason-Dixon line when spring break comes. Or certain, rather disgusting, little creatures living near undersea vents. Which may be the same thing...
M
Don't forget - on the moon you will get different gravitational readings so your accelerometric code will have to handle that as well.
Daniel
Yeah, there are quite a few things that are tough to test in the garage, tweak, upload, tweak, upload, eh!
I'm worried about cold spots -- deep shadows -- on the ground, and the rather abrupt ground to space horizon transition without any atmosphere. Mostly the former.
You are so right! Yep, we do have a vacuum chamber that we can test some of this in.
Monroe
I don't think thermopiles will work on the moon. You would be seeing the moon's surface temp or the temp of space which I think is pretty low (3 deg K ?). This is out of the range of the sensors. This would definitely be something to consider, but impossible to test unless you above the moon. It might work just from the how much of the surface is in the field of view.
If I had the resources for a moon landing I would use a machine vision system to back up and correct the gyros. I hear visibility is all ways near infinity on the moon.
Check out the Paparozzi site. Some where they explain how thermopiles work for autopilots. IMHO you might just want to use a triple redundant system using higher quality gyros.
Who's has a big enough rocket to get to the moon, let alone into LEO?
If this is one of those tests I've seen in the desert, then it would work, but that would be cheating if it wouldn't work in space. :)
Greg
Good point, I need to research this thanks! Care to expand on "Machine Vision" ?
Monroe
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
