i would just like to send only pitch angle data from arduimu to another arduino
my understanding of code is poor
i would like to know which of the following pieces of code i need to load onto the imu board to achieve this task?
which piece of code do i need to modify to send only pitch data?
Size Rev Date Author
ADC.pde 2.3 KB r46 Mar 05, 2010 deweibel
Compass.pde 2.0 KB r40 Feb 18, 2010 jjulio1234
DCM.pde 9.5 KB r48 Mar 21, 2010 deweibel
GPS_EM406.pde 5.8 KB r49 Mar 24, 2010 deweibel
GPS_NMEA.pde 9.8 KB r128 May 16, 2010 deweibel
GPS_UBLOX.pde 8.7 KB r128 May 16, 2010 deweibel
Output.pde 8.8 KB r132 Jun 03, 2010 deweibel
Vector.pde 806 bytes r1 Nov 14, 2009 j07rdi
arduimu.pde 19.0 KB r132 Jun 03, 2010 deweibel
matrix.pde 513 bytes r1 Nov 14, 2009 j07rdi
press_alt.pde 6.0 KB r53 Apr 23, 2010 deweibel
timing.pde
additional questions
is the gps required for the DCM to work if i only want pitch attitude?
which ardu-imu would be best suited to my need?
Get the ArduIMU+ V2. Load up arduimu.pde and the rest of the files will load automatically. The GPS while not absolutely necessary, supposedly helps with centripetal force corrections in dynamic situations. It all depends on the type of application you have in mind. If you have a static application - you can save a lot of trouble by just using a tri-axis accelerometer.
Daniel
If you are truly only interested in pitch AND the IMU will always have it's X axis aligned with its motion (this is the general assumption in the DCM code and why it works for airplanes but not for helicopters) then no, you do not need the gps to get good pitch information.
If you are trying to reduce the size of the code you can delete the gps files, the pressure altitude file and the compass file. However, you may need to patch the code a bit to compile with these files absent.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1267759859 seams to offer a solution without messing around with code i dont understand.
i am also looking for any info on 'autopilot feedback control loops?' to control pitch through a rudder on something like this thing given that X axis pointing forward, Y axis running through the kite string and Z axis pointing down running through the wing.
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
