Tags:
hi there, what would be the best PWM frquency to set the ESC's to? 8 or 16 khz?
thank you!
I know this is an ancient post but in any case, I thought it would be super easy to hack the eagle tree brushless motor rpm sensor and feed it into an arduino but although I got it partially working the results were less impressive than I was expecting.
In any case, here is what I did in case someone attempts to try it again at some point in the future.
1. bought one of these rpm sensors from hobbyking.
2. connected wire1 of the rpm sensor to one of the motor leads
3. connected one of the three servo style wires to an arduino uno's digital pin 2
4. grounded the arduino uno to my quad's APM ground (i.e. bottom row of the right-angle-headers coming out of hte back of the APM).
5. loaded a simple sketch into the arduino uno which increments a value everytime an interrupt attached to digital pin2 fires. the code is here.
6. printed the number of interrupts triggered in the past 0.1 seconds (10hz)
You can see from the graph below, what I did was increase the throttle in 4 steps. This was generally captured although i thought it would be a less bumpy line. You can also see that at the highest point, the uno starts reporting the rpm has dropped in half. What I think has actually happened is that it can't keep up anymore and so it's catching only half the interrupts.
I also tried attaching a small cap to the lead from the rpm meter to the uno, that didn't work at all as it just filtered out all the 'pings' from the engine and the uno reported zero rpm.
477 members
299 members
77 members
77 members
50 members
31 members
11 members
© 2012 Created by Chris Anderson.
