Hey guys I am looking for some advice on choosing a camera I have no idea what I am looking for but I know I am looking for somthing cheap =P around $150 suggestions would be nice thanx in advance : )
FlyCamOne 3 $130
hobby-lobby.com
Are you using the flycamone III? What do you think about it?
Sony Webbie seems to be popular choice
Thnx for the suggestions
@Oliver,
going for standalone cam with built in DVR or going for FPV type setup also makes difference in choice some times. You might want to look at RC switch for cams too to switch on and off your cam remotely
I know another couple other popular options are the smaller types like the KX171 and KX191 I also just saw a nice HD helmet cam get used dont recall the name of it but it may be just out or just around your price range. Also the FlyCamOne 2 gets used alot but the FlyCamOne 3 I do believe has more movement options with the lens (pan/tilt) than the FlyCamOne 2 model.
I'm using the "gumstick" video camcorder since it can fit easily into the EasyStar canopy - just cut a rectangular hole that is on the canopy downslope center and you end up not seeing the nose (unless you really want to). The camcorder can be found for about $35 with 2 gb of MicroSD - which gives maybe 40 min of 640x480 (15 or 30 fps - not really sure). The EasyStar doesn't seem to create vibration to the camera mounted like this - no wavy motion. It is only 18g in weight - really easy to use. Some examples of it (remember that the original AVI has more detail) are on Vimeo. See these:
http://vimeo.com/8766337
http://vimeo.com/8766442
I would like it to focus a little better in the distance - so far I simulate that by using the "sharpen" filter in Vdub.
You probebly won't believe this, but a cheep cvs video cam can be hacked and used with good results. See below:
© 2012   Created by Chris Anderson.
