Hi there,
Today I flew Ardupilot with FMA XY IR sensors. Since I do not have a Z sensor, I did the calibration according to the manual (each lens pointing the sky for a few seconds etc.).
The ENTIRE sky was covered with clouds (rain clouds); cloud altitude was low (~1500-2000 meters).
I tried STABILIZATION with gains that worked couple of days ago on a sunny/clear sky day.
Unfortunately today (given the weather described above) STABILIZATION worked very little to none. As I said I performed the calibration prior the flight.
Question: Would Attopilot XY and Z sensors ( http://store.diydrones.com/product_p/se-0002-01.htm ) give a better performance in such a weather- heavy clouds, low cloud altitude, entire sky covered by clouds?
It would be very helpful to find out this from people that actually flew these units in cloudy weather...
Based on the feedback I might decide to buy XYZ Attopilot sensors to try them out by myself.
Thanks!
Anybody?
You won't see any performance gain with a Z sensor. It just makes calibration happen more often which works better over variable terrain or weather patterns. I never fly with them and I've sent my plane on very long missions in bay area fog.
I would look elsewhere for your problem.
1 - do your sensors work at all? loose cables are common for IR - mine are soldered on.
2 - did you over-calibrate the sensors? Meaning did you put your hand near one while the other side pointed up. You hand is much hotter than the ground. If your IR is on the belly of your plane and you hand toss it, you could have a problem.
Good luck,
Jason
I have my sensors mounted on top of my flying wing. It might be that calibration is not done well. I will acquire XY sensors and Z sensor in the future and try again this way. In this configuration I should at least take out of the possible faults the over-calibration...
Thanks!
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
