I just finished the Ardupilot. Everthing looks great. Code loaded, GPS (uBlox5) binded, GPS locked, Sensors working ect.
Now I would like to read the GPS data into Ardustation (PC). I have the FTDI Cable correctly attached and configured on COM 8.
What do I do wrong that I can not transfer the GPS position to Ardustation? I always get the 0,0 position
In Ardustation I entered all available speeds to test and in the I/O field I tried 8, com8, COM 8 ect -> no success.
I appreciate any help.
Christof, Switzerland
Hi Christof ,
How is it all connected? Are you using xbee? a small skech will help to understand. I will be interested in knowing how your whole setup is connected? What OS in PC , how every thing is powered, checking the cable , what do you mean by trasfer GPS data etc? might help, Cheers
Hi Morli
Thanks for your help. Xbee ist not connected yet. I want simply test the data of the GPS thru the FTDI. OS is XP, std powering, cable is fine as the code ca be loaded.
Christof
Are you getting any data at all in the GCS? If not, you may not have loaded the Labview serial driver.
Hi Chris
Thanks for your reply. What means GCS? I did not load any LV serial driver. I will check now for LV serial drivers and return here in a while.
Christof
Ground Control Station = the Labview ArduStation
Hi Chris
This was the clue. I have COM 8 available now - connection established to GCS - perfect.
Now I am trying to get the data into Google earth. GE loads but the GPS information received from GCS seems not to be correct.
When I check the flight.kml from GCS Beta 2 in the "data" directory it reads
0,000000,0,000000,0 ("," instead of "." for coord decimals)
istead of
0.000000,0.000000,0
Maybe its PC related, I have to check that first.
BR
Christof
What version of Labview are you running? You can download GCS with LV ver 8.5 in the GCS thread ( by Dr.Mike & team) in this forum
Thanks for the help you provided. The system is up and running including xbee downlink. Next step is integrating OSD and then the first flight.
Christof
Hi Christof,
Good to hear it is working now. What was wrong and how did you solve it? Appreciate a feed back on it would help others who might face the same issue :)) . thanks. Looking forward to hear about the OSD side. good luck
Hi Morli
Of course you are right. I was running a XP (english) on a HP Mini book. All settings where set to german. Obviously the GPS Data was formatted the wrong way with this OS setting. ( "," <-> ".")
Now I work on a std Notebook using W7. All settings on german. (or better: same language). All application SW used so far for programming the components and view Data run perfect w W7 although the suppliers sometimes do not mention this OS version ( Example Digi - X-CTU)
Hopefully this might help.
BR Christof
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
