ok im using 2.0 code and i wan to know what do i have to change in the code and what to change it to if im using input 4 instead of input 2? Im doing this because some solder filled a hole in input 2 and now i cant get the solder out so instead im using input 4. If anyone can help that would be great. Thank you for dealing with my questions.
is this all
pinMode(13,OUTPUT);//LED pin
pinMode(6,OUTPUT); //Remove Before Fly ground
digitalWrite(6,LOW);
pinMode(2,INPUT);//Servo input -----------------------------------------------here
pinMode(3,INPUT);//Servo Input -----------------------------------------------------------or here
pinMode(4,INPUT); //MUX pin
pinMode(5,INPUT); //Mode pin
digitalWrite(7, HIGH); //Remove Before Fly Pull Up resistor
pinMode(7,INPUT); //Remove Before Fly input pin
Init_servos();
pulse_servos(0,0);
i think here to right?
byte Tx_Switch_Status(void) //Returns zero when we are in manual mode, returns 2 when autopilot mode 0, returns 3 when autopilot mode 1...
if(digitalRead(4)==HIGH)
if(digitalRead(5)==HIGH)
return 0x02; // WP mode
else
return 0x03; // RTL mode
else
return 0x00;
No your not even close. You are looking at the init_ardupilot function.That only runs once after a reset to set up inputs a,outputs ect. DO NOT mess with it at all. You could fry the board if you don't really know what you are doing (cousing two outputs to be connected). The part you want is at the end of the SERVO tab.
int temp;
static int ch;
temp=pulseIn(2,HIGH, 2000);
ch= (temp!=0) ? temp : ch;
return (ch-rx_Ch[0]);
You would change the 2 to a 4 in the third line.
The proper thing to do would be to go to Radio Wack and buy a solder sucker. They are cheap and necessary for this kind of work. Don't mess with the code unless you really know what you are doing. I've been studying it for 3 months.
I didn't know C when I began, but i do now.
Actually there would bee a lot more to it Input 4 doesn't go to the 328 just the MUX.
It would be a lot easier to just fix you solder mishap. Just heat up the solder in the hole and push the pins thru.
Careful you don't burn your fingers.
