I purchased this with full knowledge it wasn't ready to go out of the box. I'm starting this thread to consolidate efforts to utilize this GPS in the multiple projects here at DIYdrones.
I'm working with the UAVdev board and the MBED micro controller.
I have included the datasheets and associated documentation.
Here is a link to the USB installer software
ftp://ftp.leadtek.com.tw/gps/9023/MT3329_USB_Installer.zip
*NOTE: Default baud rate is 38400 not 9600 as stated in the Datasheet.
Graham,
I would buy it now as there is a limited number of the interface boards available at this time. As you know, when you do decide to buy it, it will be on backorder and you will have to wait.
I originally bought the MediaTek GPS in anticipation of the interface board becoming available and now it is. Mine should be waiting in my mailbox when I get home today.
Also, this interface board is much more robust than the fragile Ublox interface board.
Just a thought.
TCIII
Where is the documentation to interpret the binary messages the MT3329 is spitting out? The datasheet only includes the NMEA string output - not the 'compressed' binary data output.
I asked about this in an email to the diydrones store (at the contact address specified in their "contact us" link), and received the following reply from Edna:
"Jordi will be publishing the protocol and insturctions soon. Please check diydrones.com for an update."
So, basically, the product is being offered for sale (at this time) without full documentation.
It is out putting NMEA 183 protocol and it is specifically spelled out in the documentation I linked to at the start of the thread.
Example coming from mine "$GPGGA,002249.037,,,,,0,,,,1GA1,,,,EGC287,0,,0,N" matching verbatim from the documentation as expected.
I did set about playing with some protocol analysis based on your erroneous input so in that regard thanks!
Hi all,
I ordered the MediaTek MT3229 Adapter board on Sat June 19th, but the DIY Drones Store sent me another MediaTek MT3229 GPS instead. I have contacted the Store customer return email address about the mixup, but so far no response!
TCIII
Waiting for mine and hoping there was no mistake! :D
Regarding the MT3329 GPS, the DIYdrones store says the following:
"Note that the new MediaTek has custom and exclusive 'DIYDrones' firmware that allows the unit to output an efficient and very compressed binary protocol. You can still change between NMEA and Binary protocol with standard MTK messages, and switch the refresh rate between 1hz to 10hz, or set any standard serial baud rate (by default is set to 38400 bps and custom binary protocol)."
As I pointed out earlier, no documentation exists for this "exclusive" firmware with regard to the format of the "very compressed binary protocol." I'm curious how a small store like DIYDrones got the manufacturer to code an "exclusive" firmware version for them. Normally, it would require a very large quantity commitment on the part of the purchaser.
Being somewhat cautious when it comes to certain kinds of claims, I'm curious to find out more about the "exclusive" nature of the firmware, who coded it (since it's probably not based on a RISC chip that DIY folks are familiar with, nor would they have the capability of producing a mask for it), and its origins. At this time, I have trepidation toward making purchases from the store. Some honest and open communication regarding these things will help change my mind (but please, folks... no speculation... we have enough of that already).
If it helps any, found this wording on the GPS manufactures website:
"Firmware customization services available for all GlobalTop MTK GPS modules"
Hello,
I just purchased one of these with the shield from the store. I hooked it up to my ardupilot mega and loaded the example code. The blue status light on the shield is always blinking and the gps never returns anything other than 0's. Am I missing something here? Im only using the EM406 cable to connect to the gps shield to the ardupilot mega.
Ricardo
Nevermind, I got it to work. After a microscope inspection, 1 point was not touching the connector
I soldered a cable directly onto the adapter I had bought the GPS earlier and set it up for bread boarding. Those via / pads are tiny. I continuity checked as I went to make sure I didn't run into the problem you just had. I used a magnifier to do the soldering also.
Hello,
Could you please tell me where was the issue ?
I actually have the same problem.
...When i wrote this message, the blue led just stop blinking. I'm receiving datas.
So how long normaly takes the mediatek first start ?
(sorry for my bad frenchy english ^^)
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
