Hey guys, I'm trying to decide what motor to purchase for my new easystar. At first I was thinking outrunner because they are generally cheaper and lighter weight. However, I want to have the most efficient setup possible to extend flight time as much as possible. I don't really care about having insane speed capabilities, or amazing climb rates, just efficiency. The easystar (for obvious reasons) needs a small prop, so why use an outrunner motor, when outrunners are meant to be high torque motors?
So bottom line, which do you think is more efficient for the easystar, outrunner or inrunner? What size would be best for just general, high efficiency cruising?
And in terms of a prop, I've heard that 7x5 props cut down to 6x5 are really good, has anyone tried this?
Exactly!
Thank you very much to have recovered this link.
Ric
One blade also means more vibration. What is balanced statically, is not necessarily balanced dynamically under load.
That's true -- one-bladed propeller designs for rubber power often have the counterweight out a bit on a wire, and well behind the plane of rotation. The idea is to use centrifugal force (roughly speaking) to generate a torque that opposes the torque at the blade root due to thrust. I haven't run the numbers, but I'd be surprised if it worked well at other than the design RPM.
The propeller is balanced at 8750 rpm. My motor is doing 8450 – 8500 rpm. As long I’ll not exceed 8750, I’ll stay out of trouble.
The motor is a Lener type XSP turbo 1930 44 Volt – 1900/2000 watt. The gearbox is from Hacker and has a 6,7:1 ratio. I use a YGE120 HV speedcontroller and in the battery are 12s lipo cells 5000 mAh.
@Rana: I use the motor now for 2 seasons. The gearbox and motor are still clean, no grease is leaking from the ball bearings, no strange noises. In total, I charged for 89 times my 2 lipo packs. According to weather conditions, it takes 2 minutes to fly to an altitude of 500 – 600 meters. A charged lipo pack gives me the possibility to take of 3 times. After 3 times, the lipo pack isn’t flat, but have less power. A 4th take of is possible, but I reach only 300 – 400 meters.
For maintenance I use a 10 cell nicad pac of 3 cell lip pack. This gives less rpm but also no vibrations.
If you take a close watch to Rana’s first photo, you can see on the spinner (bottem of prop) that it can balance to the front and back (vertical). This means, when the prop turns, it takes the best possible position, thanks to the centrifugal force . Pitch remains the same.
Motor: http://www.lehner-motoren.com
Controller: http://www.yge.de/artikel.php?search=yge120hv
Hope you can read my bad english….
Michael
I see what you're saying - very nice!
© 2012   Created by Chris Anderson.
