My autopilot is the UAV DevBoard from Sparkfun. Mine is the "old" green board which is now superseded by this red board http://www.sparkfun.com/commerce/product_info.php?products_id=9038
I'm posting this in the hope that others will share their experiences of using this board.
It has worked perfectly and I have tested each firmware update as the designer, Bill Premerlani, has released it. It is installed in a Multiplex Twinstar which is powered by two standard Speed 400 motors. The model is quite stable, quite light and flies very slowly, so it doesn't handle wind or turbulence very well.
Although the PitchRollDemo program moved the pitch servos reasonably, at first the AileronCopilot program seemed unresponsive in pitch. I increased the PITCHGAIN from 0.125 to 0.25.
I am now using the AileronCopilot program and after each flight I adjust the control gains. When I have it returning-to-launch-point nicely I will extend the program to fly a route.
My walk around testing of the RTL function was unsatisfactory. The ailerons did something every two seconds and sometimes it was as expected. I thought it was better when I walked faster, so I tried it in the air.
The manual and stabilization modes have been good from the start. In the following video you can see the plane being buffeted by the wind just before I turn the stabilization on at 20 seconds.
At first the RTL mode was taking a very long time to turn the plane, so I reduced the ROLLKP from 0.25, first to 0.1875, then to 0.125 for the video flight. I will reduce it to 0.0625 before the next flight.
This is the 2 minute video of today's flight:-
http://s441.photobucket.com/albums/qq131/Electric_Brian/?action=vie...
The camera always points at the plane, so it not clear that the plane is about 300 yards upwind when the RTL mode is selected. The wind's speed is about 50% of the plane's airspeed, so it always ends up downwind after the turn. Most of the time the track corrections were OK, but once or twice I thought the corrections were too small and very slow.
Tags: DevBoard, Twinstar, UAV
Yep it's just a matter of PID gains.
Nice to see your project is progressing nicely. :)
Very nice, good job and good looking twinstar, transport command??
Hi Scouser,
Thank you very much for sharing your experiences. Nice work. I very much enjoyed the video. The performance is what I would have expected with the 50% wind. By the way, you said that the plane's airspeed was about 50% of the wind's speed. I think you meant to say it the other way around?
Good job adjusting the PID gains.
You are right on the money concerning ROLLKP. Raising ROLLKP increases the roll stability, reducing the bank angle, and widening the turns. Lowering ROLLKP increases the bank angle, and tightens the turns.
Regarding the RTL walkaround, you are right, you have to walk briskly to achieve yaw lock. Perhaps I should call it the RTL runaround. Its best if you go a fair distance away from the RTL point to do RTL walkaround testing, otherwise much of what you see is a response to variations in the GPS reported location. Mostly, the RTL walkaround is to make sure that you have the correct signs for the control feedback.
I am very much interested in your plans to extend the program to fly a route. Let me know if there is any way I can help.
The next item on my agenda is altitude hold.
Best regards,
Bill
Scouser,
If you are planning to extend the program to fly a route, please be aware that the range of the RTL firmware is presently about 3 miles from launch point. In principle it is possible to modify the firmware to extend the range far beyond that. The 3 mile range is presently limited by the 16 bit width of the RTL vector and the way that I use integer cordic arithmetic to compute the angle of the vector. Since this computation is done only once per second, there are plenty of CPU cycles to do the RTL angle calculation in floating point, and extend the range as far as you like.
If you want to extend the range, and it is not clear to you what portions of the code need to be changed, let me know, and I will point you in the right direction. What you will need to do is to use 32 bit differences instead of 16 bit differences in computing the RTL vector, convert the RTL vector to floating point, and use atan2 to compute the RTL angle.
Hi Bill,
It is good to get the feedback here from yourself and others. I did wonder whether we got less accurate fixes in UK than in USA (WAAS?)
The documentation has been excellent and I have followed the explanations about how the code works, except the matrix maths which I'm afraid may always be black area to me. :-( Thankfully, the matrix manipulations are not essential to grasping the DCM concept.
I don't intend to extend the range beyond the present limits. In UK we are limited to visual range. I can't see my largest model properly at 2 miles!
Did you get any further with data logging on the board?
I plan to start route flying with an array of waypoints and just change the lat_origin.WW (etc) in navigate.c to each waypoint in turn. I'll add the squares of vector_to_origin.x and .y to determine the waypoint hit, so no further maths functions should be needed. Later, I want to implement a better track keeping algorithm similar to this http://www.ee.byu.edu/faculty/beard/papers/preprints/NelsonBarberMc....
Scouser
Scouser,
Sorry, I have not gotten any further with data logging on my board.
I think the simplest thing to do might be to connect a data logger to the board's spare serial port.
Is there a data logger that you would like to use that has a serial interface?
The next best thing might be to use a separate GPS logger, such as this one from SparkFun.
Bill
Bill,
I have a tiny Garmin GPS unit that I will use for data logging.
I did make further changes to the ROLLKP. 0.08 gives me the tighter turns that i want.
Interestingly, on my last flight one motor failed. The Twinstar was high, in RTL mode, and I noticed that it weaved and then stabilised. It had lost the track, but it tried to turn back on. It overshot the track after turning towards the dead engine but managed it the other way. I think that the autopilot did an excellent job.
Scouser
Scouser,
Thank you for continuing to share your observations. The recovery after one failed motor is good news. In the back of my mind, I was wondering what would happen if you lost one motor, now we know.
What was the final approach and landing like with only one motor? Have you tried takeoffs and landings with stabilized mode turned on yet? It should work just fine.
I will be interested in your final set of gains once you have settled on their best values for you.
Best regards,
Bill
Bill,
These Twinstars originally came with "Gunter" propellers which flew off quite frequently!
The final approach and landing was not a problem with one motor out. I just set the good motor to idle and made a standard, deadstick landing.
Without the autopilot if a prop flew off at cruise power the plane would roll gently. Just after take-off (when it normally happened!) the plane would roll rapidly and enter a spiral unless the pilot was quick. I didn't try taking-off in stabilized mode. I think it would also give some advantage if one motor stopped.
My final control gains were:-
#define YAWKP 0.1
#define ROLLKP 0.08
#define ROLLKD 0.125
#define PITCHGAIN 0.25
#define RTLPITCHDOWN 0.0
#define SERVOSAT 1.0
Best regards,
Scouser
Hi all,
My first attempt at a route was interesting........
I set up a short rectangular route with legs between 260 and 570 feet and "hit distance" about 60 feet.
I used a Garmin Foretrex 101 for data logging.
The plane went off in stabilized mode and navigate was selected at about 100 feet. It flew towards the first waypoint satisfactorily, and then flew a very creditable series of attacks at the waypoint, until I reselected stabilized mode and returned to land.
The attacks looked like a dogfight with 45 degree banked turns and rapid roll rate. The plane needed some up elevator and extra power as the turns washed off the airspeed.
I've attached bitmaps from an Excell record of the Garmin's data. The first is the track, and the second is the height, speed and distance to waypoint1..
A later flight, with a bigger hit distance and 1 second logging, was unsuccessful. I think that I might have put the Garmin in the plane so that the 2 gps aerials were too close together.
My conclusions so far are that:
♦ Stabilized mode works fine for take-off and landing.
♦ I need to set the Garmin to record more frequently. In auto logging mode some records are too far apart. I will run the autopilot in debug mode on the ground to check for interference with the aerials further apart.
♦ It never hit the waypoint. Perhaps 60 feet was too optimistic, but with a gps fix every second it might not have "seen" a hit.
♦ I can make the route larger now.
Scouser
Scouser,
From your logs, it looks to me that the plane spent a great deal of time much closer than 60 feet to the waypoint. My first suspect would be implementation of switching waypoints. If you want me to take a look at your code, I will. There is an option under projects to create a zip file of the entire project that you could attach to a reply.
Best regards,
Bill
Scouser,
A couple more thoughts...
I could be wrong, but I do not think the problem is interference between the two GPS units. The EM406 must have been working properly, otherwise the plane would not have been so determined to stay at the first waypoint. It definitely knew its own location well enough.
You mentioned doing some debugging on the ground. Along those lines, a (brisk) walk around would be a good idea. Bank the plane until the ailerons go to the neutral position, and turn the plane according to the bank. This should take you to the first way point. When you get within 60 feet, you should see a response that would then steer you toward the second way point. I suspect that what you will see will be another "dog fight" to stay at the first way point. Assuming that to be the case, take a closer look at your waypoint switching logic and/or send your code to me.
© 2012   Created by Chris Anderson.
