Hi, I just got a UDB4 board and wanted to install MatrixPilot on it. However, one of the requirements is a ICD2 programmer. I do have a Pickit 3, is there any reason this would not work with the UDB4?
am quite new to PICs, only did a project arround a PIC32 before. I downloaded the matrix pilot archive from the google code project. every project i open in mplab and run project-->make/build all fails to build.
any hints/help is much appreciated.
Tags:
Daniel, the Pickit 3 will work just fine with the UDB4. That is what I use.
I hope you have seen the Wiki,
and also the main UAV DevBoard discussion group. Best wishes, Pete
Permalink Reply by Daniel Mueller on January 7, 2012 at 5:21pm yes, just getting to grips with all of that information.
i figured that some projects would not compile because they were written for the older boards, could I be right?
the UDB4 uses a dsPIC33FJ256MC710A and it seems that e.g. the UAVSelfTest was written for a ds30xyz chip?
checking out sources from SVN now, so hope i can get into the code soon :)
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.60 members
29 members
19 members
114 members
94 members
© 2012 Created by Chris Anderson.
