Hello everybody,
                        I am using Xbee
XBee Pro 60mw Wire Antenna
pair for receving the GPS NMEA string simply using xctu.I had comfigure them both for PAN id and two more things using XCTU.but i m not reading anything on XCTU .Means on the UAV side i had simply added the TX of GPS to the D in pin of breakout board on which i had added the TX xbee.And had set the baud rate as 9600(for both GPS and Xbee).LED for Din on breakout board is also blinking aproving the reception of Data at Din pin of TX Xbee,but on the RX side means the Xbee attached to laptop via another breakout board ,the RX LEd is not blinking that ,means the Rx xbee is not receving anything.
while doing the range test ,Dout LEd of RX Xbee attached top laptop is also blinking and the Dout of TX xbee on the uAV also blinking approving the reception of TEST signal.
i am very much confused what i am missing.Please help me out.
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
