UAV DevBoard pilots:
Be careful not to press on the pin headers of the UAV DevBoard, especially the gyros.
It turns out that is exactly what I have been doing several times a week, for many weeks. I do a lot of programming and I found it convenient to leave my board right in my plane while I programmed it. My board is velcro mounted, so to keep it in place while I pull away the programming cable, I have been pressing against the Y axis gyro.
I discovered today that my Y axis gyro was not responding. I think I have made several flights without benefit of its signal.
A little heat on its pins got it working again. My theory is that there was a cold solder joint that opened under the strain of my pressing on the gyro. I contacted SparkFun, and they recommended that we should not press on any of the headers. This is the reason that they cited for why they trim the excess off the header pins before they solder the pins. They also said that they would take extra care to make sure the gyros are well soldered into the board.
In the process of losing the Y gyro signal, I learned that MatrixNav will provide adequate performance with only 2 gyros and 3 accelerometers. 3 gyros provides the best performance, but with only 2 gyros, the DCM algorithm managed to track well enough to keep the plane level and to return it smoothly to the launch point.
Also, in the process of trying the board on a helicopter, it was found that vibration will open any cold solder joints.
So, I have the following recommendations:
1. Do not press on the headers of the UAV DevBoard, especially the gyros.
2. If you have been pressing on the gyros while you remove the programming cable, run the
roll-pitch-yaw demo to make sure all three gyros are still functioning.
3. If you find one of the gyros is not responding, or if the board has been subject to vibration, or if the gyro connections do not look like they have been heated enough, resolder the pins that connect the gyros to the board and rerun the demo to check it.
Best regards,
Bill Premerlani
