My XBEE only transmits for a second, then quits until I reconnect it.
I have an XBEE PRO attached to the XBEE Adapter, and then attached the 3 required pins to the Shield Version 1. I then have the 2nd XBEE attached via USB and it's terminal opened in X-CTU. My ArduPilot is running V2.4. and on my terminal reads:
++ASP:-277,THH:84,RLL:60,PCH:1,***
.+++ASP:-274,THH:84,RLL:60,PCH:1,***
.+++ASP:-279,THH:84,RLL:60,PCH:1,***
.!!!LAT:XXXXXX8,LON:-9XXXX12,SPD:1.22,CRT:0.60,ALT:11,ALH:46,CRS:292.90,BER:219,WPN:0,DST:11,BTV:0.00,RSP:-35,***
.+++ASP:-277,THH:84,RLL:60,PCH:1,***
.+++ASP:-278,THH:84,RLL:60,PCH:1,***
.!!!LAT:XXXX68,LON:-XXXXXX,SPD:1.01,CRT:0.44,ALT:10,ALH:46,CRS:287.50,BER:203,WPN:0,DST:9,BTV:0.00,RSP:-35,***
.+++ASP..bRRRj.+++AS.!!!L....
It appears to transmit some random periods and characters ("bRRRj") at the end for some reason... Also, if I disconnect it, and reconnect it while the Ardupilot is running it will send a few more packets of data.
Anyone have any ideas why this is happening?
I think I have successfully had transmission using the "Range Test" in X-CTU, one connected via FTDI, and the other USB breakout.
Thanks,
Matt Evans
Permalink Reply by Maynard on January 29, 2010 at 12:56pm
Permalink Reply by MattEvans16 on January 30, 2010 at 2:40pm
Permalink Reply by MattEvans16 on March 13, 2010 at 12:51am
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.95 members
61 members
57 members
108 members
617 members
© 2012 Created by Chris Anderson.
