An Unmanned Aerial Vehicle (UAV) is an aircraft that has the capability of autonomous flight, without a pilot in control. Amateur UAVs are non-military and non-commercial. They typically fly under “recreational” exceptions to FAA regulations on UAVs, so long as the pilots/programmers keep them within tight limits on altitude and distance. Usually the UAV is controlled manually by Radio Control (RC) at take-off and landing, and switched into GPS-guided autonomous mode only at a safe altitude. (Confused by all the acronyms and unfamiliar terms in UAVs? A glossary is here.)
---1) An RC plane, muticopter (quadcopter/hexacopter/tricopter, etc) or helicopter (see good starter plane options here). You can buy them ready to fly, including autopilot, here.
---2) An autopilot, such as APM 2.5 (see below)
---3) Optional: a useful “payload”, such as a digital camera or video transmission equipment
The DIY Drones community has created the world's first "universal autopilot", ArduPilot Mega (APM). It combines sophisticated IMU-based autopilot electronics with free Arduino-based autopilot software that can turn any RC vehicle into a fully-autonomous UAV.
A full setup consists of:
You can buy Ready-to-Fly UAVs (both planes and multicopters) from uDrones:
Comment by Noah King on January 29, 2013 at 6:58am does the APM need an external GPS unit, and if so what does this look like/ where can i get one.
Noah. Yes. The GPS comes with the APM autopilot. It looks like this.
Comment by aerotech on January 29, 2013 at 3:49pm very nice, how can create the fail safe recovery for APM 2.5? thanks
Comment by Garry McLeary on February 7, 2013 at 5:25pm Hello,
I am a newbie trying to set up a hardware-in-the loop simulation with xplane, but I am having trouble getting it to work. I am following the instructions on the wiki for xplane (is it still current?) However when get to the where I run the simulation using the "Sim Link Start/Stop" button on the simulation screen, I get the following error message:
Socket setup problem. Do you have this open already? System.Net.Sockets.SocketException: Only one usage of each socket address (protocol/network address/port) is normally permitted at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.Sockets.Socket.Bind(EndPoint localEP) at ArdupilotMega.GCSViews.Simulation.SetupUDPRecv() at ArdupilotMega.GCSViews.Simulation.ConnectComPort_Click(Object sender, EventArgs e)
I have checked and re-checked the port numbers and I believe they are setup correctly. Here is what I have:
for the Planner, in the "Advanced IP Settings" on the Simulation screen,
in the field for "Enter Sim pc IP" I have 127.0.0.1
in the field for "Enter Sim pc Port" I have 49000 i
n the field for "Enter Planner pc Port" I have 49005
In Xplane, under Settings -> Net Connections -> Data,
I have the box next to the port numbers 127.0.0.1 and 49005 checked. Below that for UDP Ports I have:
"port that we receive on": 49000
"port that we send on": 49005
Mission Planner version #: 1.2.33 mav 1.0 xplane version#:10.05r1
I am using the APM 2.5 board connected to a USB port on my computer. It is recognized as COM port 3 in device manager, and on the Firmware screen in Planner, COM port 3, with baud rate 115200 show up on the screen.
I tried re-installing xplane as suggested in the forum but that didnt work. Any idea what I could be doing wrong?
Garry
Comment by Juan Garcia on March 4, 2013 at 5:04am Hi,
I am using the apm 1.4 version and like it very much. Can i safely upload newer firmware to this, like the 2,70 version? Or are they strictly limited to the newer Apm 2.x versions? Which firmware should i use best?
John
@Juan,
If your APM1.4's processor is the Atmel 2560 you should have no problem with the newer versions of the code. I assume that you have an Oilpan attached to the APM?
TCIII
Comment by Juan Garcia on March 4, 2013 at 6:11am Yes, there is an oilpan. I dont remember the name of the device and i don't have it at hand. Wasn't it "hotel" version??.
@Juan,
The "Hotel" refers to the latest version of the Oilpan. Some of the APM1.4s still had Atmel 1280 mcus which had less memory than the 2560s. You need to look a the top of the processor to see what Atmel p/n is on it.
TCIII
Comment by Juan Garcia on March 4, 2013 at 10:21am @ Thomas J Coyle III
Thanks a lot for helping. My 1.4 has the Atmel 2560. So I can happily live with the new software.
John
Comment by Chris Cashmore on March 4, 2013 at 12:09pm Ok, I have been asking basically the same question, but I have the 1280 processor. It says so on top of it.
What is the latest version of code I can run on it I dont need data collection, but would like to use waypoints etc.
I would really like a definitive answer so I can get on with this thing. I believe the last code I had on it is the NG cod from ardupirates.
184 members
74 members
685 members
133 members
Powered by
