Jeff
9.2 inches tip to tip. Will it fly??!!
Rotors pitched to induce nose-up pitch and counter-clockwise yaw
I am beginning to think that this is do-able. it looks very heavy, and i need to do the math to figure out how much thrust I can get out of my brushed motors. I reduced rotor diameter, added a horizontal stab, and added a canopy so it looks more fly-able.
The fun part is almost over, as I need to start diving into the math to make sure this will fly.
Mariano Gros Comment by Mariano Gros on February 9, 2010 at 1:45pm
In my opinion you only need to turn rotos in front back direction, not in right left side. You can remove two servos.
Jeff Comment by Jeff on February 9, 2010 at 2:15pm
Thanks for the comment. By tilting the rotors inwards/outwards, I'll control pitch (nose up/down). As shown, tilting rotors inwards towards center line will create an upwards force on the outside of the rotors, which will travel 90deg to the front tips of the rotors, pulling the nose up and inducing pitch.
Without this control, I am not sure how I would keep the nose of the craft level, especially when hovering with little airflow over the horiz stab . Thoughts?
Mariano Gros Comment by Mariano Gros on February 9, 2010 at 3:59pm
I'm thinking in Osprey V22
http://www.youtube.com/watch?v=QB4pgsPUkHw
I believe It only tilt rotors front/back.
IKE Comment by IKE on February 9, 2010 at 4:11pm
The V-22 has collective pitch-control, and cyclic pitch-control, I think Jeff is trying to compensate for the lack of cyclic / collective with the extra servos.
Daniel Gervais Comment by Daniel Gervais on February 9, 2010 at 4:38pm
you only need 1 servo to aim the rotors outward. You can gear it to get equal movement out of each side relative to the main body but at this scale it probably doesnt matter.
Zane the brain Comment by Zane the brain on February 9, 2010 at 5:13pm
i think you should do what mariano says, as you will still have control, and it will lose some weight.
ernani reis Comment by ernani reis on February 10, 2010 at 5:07am
I suggest checking these: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=..., seems promising. (counter rotating twin motor pack with propellers)
bGatti Comment by bGatti on February 10, 2010 at 8:20am
I agree with jeff, that skewing the axis in and out will result in asymmetric forces on the pitch axis. I'm not sure I follow the explanation, but assuming counter-rotating blades; if the forward-moving blades are higher than the rearward-moving blades, then the airframe would indeed pitch upwardly - Which means the avatar design is feature complete?
Morli Comment by Morli on February 10, 2010 at 5:23pm
May " target="_blank"> this will help, it is called tandem trex The controller can be found here with airframe details/kits
Comment
© 2012   Created by Chris Anderson.
