Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
hi, i have an apm1 can t it work with arduplane?
Glad it's working. Happy to help if you have other questions.
Austin: Yes. Details in the manual.
I correct myself, it reads "a pro-level UAV system for planes of all types".
Tks Chris, link is okey now.
Any chance of making a power neat regulator (like the one in the pic) that will do for 7s LiPo. I am using a UBEC at the mo, but like this solution better and I'm too lazy to do it myself ;-)
Frederico, the links in the post above all work for me. There may be some old links in the comments section from users; please ignore them (we can't control user links)
Comment by Ife O Ogunleye on October 8, 2012 at 5:45pm
When i click on the "Telemetry kit" link, I get the follow error message.
Comment by Chris Anderson on October 8, 2012 at 5:53pm
Ife: Good catch. Fixed!
This is seen on pag. 70, but it continues happen to me.
Tks.
1
2
3
4
5
of 59 Next
