Here is a Simulink airplane simulator working together with aerodynamic coefficients and stability coefficients computed with Mark Drela's AVL program.
The simulink model file is P.mdl:
The aerodynamic coefficients and stability derivatives are functions of the Angle of Attack and are written in the P.m file (Super Chipmunk):
P.m
I have computed the coefficients of the CG Super Chipmunk and of the Scorpio Miss Europa. Miss Europa is the sistership of the Super Miss, Icebear's famous airplane (good job Icebear !)
Below are the AVL files used to generate the coefficients of the Super Chipmunk:
Below are the AVL files used to generate the coefficients of the Miss Europa:
And the resulting file for Simulink:
If you want to compute the coefficients for another airplane, you need to create the .avl, .mass, fuselage.dat and airfoil.dat files and run the AVL program a few times (for every AoA). If some of you guys are interested, I can write a draft on the way to generate the coefficients with AVL.
If you just want to test the simulator with the Super Chipmunk, you just have to type P at the Matlab prompt and then launch the P.mdl file.
This P.mdl simulink model has been used to test the DCM algorithm and also the EKF.
If you want to have a look, here are the R.c (DCM) and EKF.c (Extended Kalman Filter) S-Functions.
You need to compile them. At the Matlab prompt type "mex R.c" and "mex EKF.c"
Otherwise get rid of them in the P.mdl model.
December 20 2011 Update
I have corrected :
- a mistake in the computation of the force wrench (bref was used instead of cref for the moment M)
subsystem Aerodynamic Model
- a mistake in the moment of inertia tensor (sign of one of the product inertia)
subsystem Equations of Motion
I have also unified the format of the stability derivatives
subsystem Aerodynamic Model and files P.m
So here are the new simulink model and the stability derivative file
- for the Super Chipmunk airplane :
- for the Miss Europa airplane :
These files replace the previous P.mdl and P.m files.
Here is also the DCM program you need to compile with the Matlab compiler (you may get rid of this function if you like) R.c
Comment by Rhett "Wreck" Phillips on February 19, 2010 at 3:52pm
Comment by Borja Martos on February 19, 2010 at 7:46pm
Comment by Borja Martos on February 19, 2010 at 7:54pm
Comment by Paul Bizard on February 20, 2010 at 2:41am
Comment by Paul Bizard on February 20, 2010 at 2:53am
Comment by Paul Bizard on February 20, 2010 at 4:25am
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.61 members
57 members
95 members
108 members
617 members
© 2012 Created by Chris Anderson.
