http://www.kickstarter.com/projects/1013469813/mygeekshow-get-into-rc-airplanes
This week I tested the Ardupilot's waypoint and autopilot functionality again, and this time, had a lot more success! I moved the GPS unit to have a better view of the sky, and it's performance improve markedly.
I also tried taping my iPhone 4s to my airplane and used it's 1080p HD video function to record the flight. Totally revealing how much better a nicer camera would look! I need to balance the prop to reduce all the waves and distortions, and of course improve efficiency and reduce damage caused by the vibrations.
Again, so far so good. I am really loving the APM and mission planner. Thank you again DIYDrones for the awesome equipment and software!
Equipment Used:
Airplane: Scratch-built Nova, see http://www.MyGeekShow.com for plans and build instructions
Main Camera: iPhone 4s
Airplane Camera: FlyCamOne2
AutoPilot/Stabilization: Ardupilot Mega from http://www.DIYDrones.com
Motor: http://www.hobbypartz.com/75m42-optima450-2220-950kv.html
ESC: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=13429
Battery: http://www.hobbypartz.com/77p-sl4400-3s1p-30c-3333.html
Servos: http://www.hobbypartz.com/topromisesg9.html
Prop: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=5437
Stats:
Weight: 32 oz
Thrust: 21 oz
Wing Area: 3.33 square feet
Wing Loading: 5.3 oz per sq ft
If you're interested in building the Nova, I've got free build instructions and plans on my website: http://www.MyGeekShow.com.
-Trent
Good job. I can see how the motor vibration is causing the "jello" affect in the video. When you cut the throttle it gets very clear. I also noticed with the throttle cut in stabilize you were level and descending fast. This is a high alpha condition and you could be close to a stall. Be careful.
