I'm new in Multicopter hobbies. I'm french so excuse me for my poor english.
My project : Create a quadricopter with K'nex parts.
I have created my frame its weight : 450g.
I have 1 or 2 Lipo pack 3S 5000mAh 30C (360g each).
I'm searching a good motor but i think i need help..
In fact i want have 10min run time. But i can't use Motor AC2836-358, 880Kv because 450g + batterie is too big isn't it ?
If my total weight is 1500g :
i need 4 motors with max thrust 375g. Or i have seen on this forum that the best practice is to set motor at 1/3 ratio weight/thrust
375g x 3 = 1125g so i have choose this motor :
Battery: 2~4 Cell /7.4~14.8V
RPM: 1000kv
Max current: 30A
No load current: 1.7A
Max power: 430W
Internal resistance: 0.052 ohm
Weight: 102g (including connectors)
Diameter of shaft: 5mm
Dimensions: 35x36m
Prop size: 7.4V/11x5 14.8V/10x6
Max thrust: 1160g
Max current is 30A and i think that the average is 1/3 of this (on an normal flight) isn't it ?
This page said me that my fly time will be 10minutes with 5000mAh / 30A:
http://www.scoutuav.com/2011/05/12/calculate-flight-time/
Can you confirm this ? (I know it is an estimation sure :) )
Thanks for your reply
PS : i will post some photos later :)
Christopher
Sure i don't need to limit max thrust. Just don't push max my stick lol.
I think that the AC2836-358 is a good idea :)
I will buy it and post some picture of my quad there :)
thanks
Christopher
I think i have found compromis :
K'Nex Frame 450g
Electronique 100g
Lipo 360g
Motor (AC2836-358, 880Kv) 288g
Esc 84 g
Total 1282g
1282g / 4 * 3 = 960g
With this configuration, AC2836-358 need to thrust 960g max (with 1/3 ratio)
Wattage
Thrust
17.5W
230gr
70W
650gr
160W
1290gr
210W
1380gr
If i set my ESC at 75% my motor can thrust 1290 that is better than 960g.
14.2*4 = 56.8A if i set full gaz constantly
if i estimate that average will be at 1/3 :
56.8 / 3 = 18.93
http://www.scoutuav.com/2011/05/12/calculate-flight-time/ said me more than 15min fly time.
I think it is a good solution.
Anyone can confirme that ? Thanks for your interest
Christopher
